I'm using the "Replace with reference" function in Find Duplicates a lot - this is a great feature and a really good implementation.
My car stereo has USB input so I frequently copy MP3 files to a USB stick for in the car using right-click "Send to" > "Folder (Copy)".
However this copies the ASX file not the MP3 that it references - which is a bit useless when playing from the USB stick.
Could the function be tweaked to copy the original MP3 instead please?
As a side note, how does the ASX file store the 5-star rating? Is it updated in the original MP3? Or just in the MB database?
I don't really know but it'd seem to make sense to update the original MP3 since the ASX file indicates that it's a duplicate, and therefore you'd be unlikely to rate the same song differently?
