Author Topic: <Channels> in column browser  (Read 1299 times)
cynflux
Hello,
Is there a way to add a column that show the files that are Stereo and Joint-Stereo?
I can't seem to get it to work.
Thank you in advance.
Do you mean this?
In Tracks or Albums & Tracks View right-click on the header > Set Displayed Fields > select Channels from the Other Fields section and drag to the right side.
In Albums View > right-click on the header > Customize Panel > select Channels for one of the four dropdowns.
cynflux
Thank you so much for response.
I was actually able to accomplish what I wanted by creating a custom tag called Channel Type.
The custom tag either has the string 'Stereo' or 'Joint Stereo' and is in a column browser section.
