Author Topic: Preserve missing Monitored Folder library  (Read 878 times)
pleiades
Hello,
I'm using the portable version of musicbee and when I want to add a new folder to the monitored folder, the unavailable folders are removed. it should preserve the missing folders and let the user decide if they want to remove a monitored folder or not.
Thank you!
What version of MB are you using? Not that would make a difference because I don't think the monitored folders code has changed in years. And it doesn't behave as you describe for me. Library > monitored folders > Choose Folders. It opens up a tree view of your folders and you select what you want to monitor. I just tested by adding two folders to the two that I already had set and MB now shows four folders being monitored.
Perhaps a screenshot of your Library settings might be helpful.
screenshots: http://musicbee.wikia.com/wiki/Posting_Screenshots
