Sorry to late, but I had some issues have to be resolved.
I need clarification for:
Track Gain
Replay Gain Off
Smart Gain
Scrobble
Volume Minus
Volume Plus
That takes long time because I'm comparing with Microsoft Arabic glossary, to gain as much as language translation quality
Thanks for understanding...
Since you only need an explanation to help you choose the right words, I wont go into any detail
Track Gain: Automatically adjusts the volume of the playing track so the volume stays the same - the technology is known as Replay Gain
Replay Gain Off: Disables the above ie. no adjustments made to the volume
Smart Gain: Also automatically adjusts the volume of the playing track but so entire albums stay the same volume, except when shuffling, in which case adjusts all tracks to the same volume
Scrobble: I suggest you dont translate - its a technical term applied to when track playcounts are submitted to last.fm - last.fm users should know what scrobble means
Volume Minus: Decrements the volume by a small amount
Volume Plus: Increments the volume by a small amount
