@AvikB, so would the xml block you describe be available similar to: https://getmusicbee.com/rss/ ? I would suggest including the update date/time in UTC format as well in case the plugin developer forgets to increment the version info
Yes, kind of similar.
@Steven; How about allowing, optionally, each plugin to use its own sub-folder under MusicBee\Plugins folder? Some plugins are using the same filename for different files and Plugins folder is quite messy.
This would extremely useful.
Then skins (both xml & xmlc) & TM need to include just name and version at the beginning of the code? Maybe name could be optional if it's the same as filename? I think that's the case for most skins except skin sets.
Some skins are in binary format. so that won't work.
but this wont work for theater modes, visualizers and skins. i don't think its very hard for devs to include 1 small xml file into add-on zip.
also i wouldn't rely on add-on version at all. for example there is no versions at all for most skins. update date is most important for comparison of versions.
Right now i think my priority is to have an plugin updater. I will add update options for skins and others at a later date.
So the updater can read the xml, query the website (over the existing API) for the latest version, compare it to the one in the PluginInfo and then display a notification.
I would not add the version to the xml because you would have to change the version in two files and we already have the version in the PluginInfo class. This way you could even generate the xml and download it over the website when you create a plugin, because it would never change.
Yes i think Steven and you are right about using the update date.
@AvikB: if you write example update notifier plugin to integrate it into mb later, write it in visualbasic as mb is written in vb.
About that..... i am not comfortable with VB
. I will write it with C# and WPF. maybe winforms but i like WPF better so there you have it. I don't think it needs to be integrated directly into MusicBee. It should be a standalone plugin, maybe included with MusicBee by default.
for update notifier ui: i think that displaying message box with updates at mb startup would be very boring. its better to have a button on mb title bar with image of balloon and number of updates. user can click this button to view the window with all updates. just like in visual studio. also an option to ignore given update (not to remind about it anymore) might be useful.
I will keep that in mind. But before that we need a working solution first
I will start working on a updater system this week. hopefully i will have a standardized structure for the XML data and an basic update notifier.
Let me know what do you guys would like to see.
