Author Topic: what do i do with this error report musicbee said report it but not where to  (Read 903 times)
Chris15129
MusicBee v3.1.6590.33030 (Win10.0), 7 Feb 2018 5:27:
System.IO.IOException: The system call level is not correct.
   at #=z2P8h3qsPnP9x4L9W2prqMQxL3d3O.#=zltbtA88sPfAebRoVBg==(#=z88wOfaCGeaMTPyIqug== #=zYko$DNU=)
   at #=z2P8h3qsPnP9x4L9W2prqMQxL3d3O.#=zpBXpckg=(#=z88wOfaCGeaMTPyIqug== #=zYko$DNU=, Boolean #=zQEgfdc53ovbOgtU_qA==)
   at #=z2P8h3qsPnP9x4L9W2prqMQxL3d3O.#=zpBXpckg=(#=zZMpEksCnvjgoV_zRyHdVhh8= #=z8em79r8=, Boolean #=zQEgfdc53ovbOgtU_qA==, Boolean #=zQJx7Kk5RC7zj)
   at #=zcXxWOdu2TT9OMfNBd7dcbA0=.#=zpBXpckg=(#=zZMpEksCnvjgoV_zRyHdVhh8= #=z8em79r8=)
   at #=zhjcxBe3RKe7rdLo3rkbLjn8=.#=zswWP_oU=(#=zLRK_zyniu4eKmJeDCc$kr4w= #=zNndBmYM=)
   at #=zhjcxBe3RKe7rdLo3rkbLjn8=.#=zroNAZRvYAUcf(Object #=zK6Z6rIc=, EventArgs #=z79k3W$8=)
   at #=z4KQEmLYFKcS8h5G3MN3v5Jc=.OnClick(EventArgs #=z79k3W$8=)
   at #=z4KQEmLYFKcS8h5G3MN3v5Jc=.#=zFKP5qpzBx6Mb(Object #=zK6Z6rIc=, EventArgs #=z79k3W$8=)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
This is very strange as you are the 2nd person to report this error in the last couple of days.
Does it happen with any file you delete?
There is a patch version that will revert to permanent deletion if deleting to the recycle bin fails:
