I've been using this for a while and I love it, but when the artist + song name is too large, it cuts off like this:
Do you have any plans on making it scroll like Spotify does (if it's even possible?)
Thanks!
I would like to implement this but currently this is a feature request at Discord (
https://github.com/discordapp/discord-rpc/issues/146). It is not possible to do this in the plugin, so you have to wait for Discord...
Anyway the screenshot does not look like my plugin, are you sure this is the right thread? Because I am not cutting of song names, only album (see below)
maybe the dev can change it so the song title is at the top and the artist is at the bottom
i use a different discord plugin (https://github.com/wiiblob/mb_DiscordRichPresence) and i think it looks much cleaner that way.
anyone knows if these plugins are able to pull cover art from last.fm or musicbrainz, instead of showing the musicbee icon?
The Plugin you mentioned is not displaying the album in the presence text fields (it is using the image text for this). I tried to display as much data as possible in the given fields and decided that the album is the least significant one, that is why it is in the position that currently gets cut off.
For pulling images, there is an issue (
https://github.com/sll552/DiscordBee/issues/3) for this, unfortunately this also requires changes from Discord.
