I've just started using MusicBee and I love it. But there is something I really miss.
One of the features that I love the most in Winamp is the very simple and intuitive "Play Random Album" function it has.
In Winamp, you right-click anywhere in the main panel and select "Play Random Album". Winamp will clear the playlist and insert the random album, playing it immediately.
Alternatively, the user can select "Enqueue Random Album" and lengthen the playlist for later.
Now, compare with MusicBee. Granted I have just started using it but when I select "Queue Random" it seems that MusicBee will do something very strange...
If I click "Queue Random" from the column, for example, of a certain genre
The playlist gets filled by ALL the albums in that genre IN ORDER!?
How is this random???
OK, maybe this is a bug or I have the wrong configuration somehow?
BUT ALSO, randomness in such a case IMO works like this: the software picks something for you, but then it's up to you to decide whether you like the choice.
In Winamp, if the random choice is something I don't feel like listening to, I just click "Play Random Album" again and try with another.
(to clarify, I have thousands of albums and it is often not convenient to delve into the library to look for a certain album I cannot even think of).
In MusicBee, if I repeat the "Queue Random" command all it does is to enqueue to the existing playlist. But what I really want is for the player to STOP playing what it's playing and start playing something else!
To do this in MusicBee (correct me if I'm wrong), I have to get into the playlist, select all, clear it, try to "queue random" again.
All I'm saying is that it would be great to have a more practical way to get the player to PLAY a random album from the main panel in ONE click.
