Author Topic: ProTunes  (Read 19297 times)
ghaffy
railfan-eric28
FYI the updated link isn't working now.
I'm using a Galaxy S21, Galaxy 9+, Galaxy S7, a Galaxy Tab S 8.4, Poweramp, and Musicbee.
johnmillsjr
What do I need to adjust to fix the player bar and other things?
p4453697
The Openload link is dead--any chance for a reup?  Thanks in advance.
Doesn't look likely as the developer of this plugin hasn't been on the forum since last January.
There might be a user or two who use this plugin and they might be able to upload it somewhere.
1800-Magnolia
  • Tester
mayo
I know I'm necroing this old thread, but the skin doesn't apply to Musicbee.
The xml file's in the skin folder as intended and accessible from the drop down menu. Other skins from that location work fine.
Kindly, please advise
Cheers
… the skin doesn't apply to Musicbee…
Trying it out, it's working for me.
What exactly indicates to you that it doesn't?
mayo
when MB restarts, the layout doesn't correspond to thumbnails layouts describing the end product.
…the layout doesn't correspond to thumbnails layouts…
Skins do not define or control layouts.
Only colouring and—usually—image elements.
mayo
then it perfectly works as intended. playing with panel configuration tools I managed to make it look very Itunish. quite happy with the end result.
thanks for your quick reply
You're welcome.
I personally prefer MusicBee to look like MusicBee. (whatever that is ;-)
mayo
aye I feel you my friend - I'm just a creature fo habit slowly freeing myself from the matrix :)
and whilst I'm at it - is there a way to add a small play button same line as each song title?
... like "look like MusicBee" ? xD
There already is a 'playing' icon:
I guess you could post a request to have some 'play' icon in that same vertical space, but I imagine it would not be an improvement on having a clean and efficient interface. (so I would probably vote against it)
And you can already play a track by simply double-clicking it or pressing [Alt]+[Enter]
