Would be great if there's an option in the volume analysis dialog that treats all added (selected) tracks as a single album for album gain values.
Then if you're using folder option for album grouping, you don't have to add all tracks into a single folder just for volume analysis.
Also it would make it possible to apply the same album gain values to all albums in a box set.
