Hey - I only just remembered this thread seeing some of the other asio/kHz threads.
Here's a file with 22kHz (& 96kbps...) from a free release, playing a lot faster than intended...
https://files.fm/u/cb8h7zwtAlso, as I have read that in one of the other threads this might be a bass issues, but even with this patch:
https://getmusicbee.com/forum/index.php?topic=23992.msg140544#msg140544I now get a fair bit of issues - first of non-descript error:
[Error
Unable To Start Playback]
After playing the above file fine first, MB won't play any other samplerate files anymore from the looks.
Oh, actually, I'm lying... now MB won't play any files anymore at all, no matter the samplerate, and all I get is the above error, even the 22kHz one is erroring now which I started with.
I'll restart MB.
After a restart, I was able to jump between different resolution files again, only lower than 44.1kHz for now, which showed the usual sped-up playback behaviour I mentined here. But, then jumping back to higher than 44.1kHz, 48kHz ones played fine, but now I get the same error:
[Error
But this time around with 96kHz samplerate files only. Other lower samplerate files play this time around still (but all show the speed up / slow down issues tied to samplerate from the looks...)
So very different behaviour all together seemingly depending on what is played in which order...?
Strange.
c.
