I followed these steps, and had the described unexpected results. Signature contains updated information about the installation.
1. Select an Album in the browser.
2. Select all tracks listed.
3. Edit, rename the album, and "Save."
In the Column browser, the next album listed is highlighted, but the tracks shown in the main pane do not update. Clicking on the selected album in the column browser does not update the list. Selecting another album, and then the previously highlighted album is the only way to update the track list. (Clarification; "Next Album" is the one below if Album is sorted ascending, and the one above if sorted descending.)
In the course of testing before posting;
- If I double-click the incorrectly highlighted album, the tracks listed will play, instead of the tracks from the album indicated in the column browser.
- Reduced to only "Album" in column browser, performed the same steps, and it seemed to work as expected. I repeated the test, and found the same issue listed above, several times after.
*Edit to add first line of text missing from paste.
Dell Inspiron, i5, 16GB, 256GBSSD
Windows 11 Preview
MusicBee 3.5.8447, standard install on C:\
Library on External drive;
293,621 Tracks, 18,393 Albums, 4461.93GB, 850d 12:20
Topping D10 32bit 384 kHz USB DAC
O2 Headphone Amplifier
beyerdynamic DT770M 80 ohm
Crossfade M-100 Master Over-Ear
