right click on the header bar above "Auto-Playlists" and untick Show Playlist Header
I notice a glitch on the left of the MusicBee button. Would you mind sending me a zip of the following:
- your settings file (help/ support/ view settings)
- and the bitmap image for the custom background
That did the trick steven, thanks for the tip bud
That glitch was a bug in the skin file which was discussed here on the forum after which the author updated it. It's associated with that specific skin only.
If you still want those files, just drop a line.
