when you updated to v3.2, did you replace the existing musicbee.exe or did you set up a new folder for v3.2?
if you set up a new folder, and referenced the old library then you will run into this sort of issue ie. you should replace musicbee.exe from the v3.1 folder or alternatively set up a new library for the v3.2 portable folder
hi
i have download all the portable zip file 12.802kb ,and i update in the right folder overwriting all the files
i have tried to create a new portable version in another partition , import the audio files in this case , and they have no tags
weird because it happens with not all my music files
for example the new update does not read my audioslave albums but read correctly my radiohead album
it's very weird , mp3tag read them ,foobar too
i can post a screenshot of a new clean installation ,with my audioslave album tags missing
it's weird i know
these are screenshot of a new clean install , i have imported only 4 subfolders
and how you can see many songs have an exclamation point
thanks Steven
