Author Topic: number of artists in a library  (Read 2029 times)
cynflux
Hello,
Other than the library report tool, is there a quick to determine the number of artists are in a library?
Thank you in advance.
On the music panel, if you select to view by artist, the first entry should be "All" with a total number of artists below it.  Same for Album Artists, Genre, etc.
cynflux
Thank you for the reply.
Could you post a screenshot of what you are referring to?
I get the panels confused sometimes.
cynflux
Thanks for the screenshot. I was able to get my panel arrangement to look like yours on my PC at home.
On my flash drive, however I can't get the column browser to appear above the tracks section.
The column browser always appears on the left with only one column with just Artists.
It's very frustrating.
cynflux
I figured out the problem. Column Browser was not set to Horizontal.
Connor
Got it! Thanks.
