Author Topic: Visualizer Makes the Music Play Faster  (Read 1495 times)
Thalion Korvhas
Whenever I use most of the visualizers the song speeds up almost double time. When I exit the visualizer, it returns to normal. How can I fix this?
mcool
It happens also to me but only when I use wasapi or asio output
Thalion Korvhas
This also occurs on MusciBee v2.4 which I have installed alongside the most recent version of MusicBee. So this issue with wasapi or asio output has been around for a while. Once I changed to ASIO the difference was huge in terms of quality. So I have no intention of using the standard setting.
I do not have the knowledge or understanding of why this behavior happens. Is it something that can be fixed in the code or one of those hard to squash issues?
NickIst
I have the same problem. The Alchemy is the only working
