Author Topic: filtering by no volume analysis, album gain, track gain, etc.  (Read 886 times)
cynflux
Is it possible to set up filters to show the following:
files with no volume analysis
files with track gain only
files with album gain only
files with track gain & album gain
Thank you in advance.
If a field you're looking for to define a rule is not available for auto-playlists or filters, you could create it using virtual tags.
For instance,
<Album Gain>
will give you a virtual album gain field and you could use those fields for defining rules (using "has a value/no value" in this case).
