Author Topic: adjusting replay gain value  (Read 768 times)
cynflux
Hello,
Other than manually sliding the replay gain value left or right, are there any keyboard shortcuts to adjust the replay gain value? The only one I have found is Left Arrow and Right Arrow which moves the value either +.5 or -.5 depending on direction of the arrow. Is there one that will adjust by .1?
Thank you in advance for your reply.
