Author Topic: option to not remove empty folder when organizing files  (Read 960 times)
cynflux
Hello,
Is there a way to set an exception to have MB not remove an empty folder when organizing files?
I am using a folder called converted which is where my encoded mp3's are being saved to.
Once I have all the tags and artwork set for the files, I then run the organize files command on the mp3 files. Once it's done, it always deletes the converted folder.
I am open to suggestions if an exception is not possible.
Thank you in advance for your reply.
Create a textfile and put it in the folder. I gave mine the filename of "Placeholder - Do Not Delete.txt" and in the file the text "dummy file."
cynflux
Great suggestion. I also made the text file Read-Only. Thanks again
You're welcome.
