Author Topic: option to not remove empty folder when organizing files  (Read 770 times)
cynflux
Hello,
Is there a way to set an exception to have MB not remove an empty folder when organizing files?
I am using a folder called converted which is where my encoded mp3's are being saved to.
Once I have all the tags and artwork set for the files, I then run the organize files command on the mp3 files. Once it's done, it always deletes the converted folder.
I am open to suggestions if an exception is not possible.
Thank you in advance for your reply.
Create a textfile and put it in the folder. I gave mine the filename of "Placeholder - Do Not Delete.txt" and in the file the text "dummy file."
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
cynflux
Great suggestion. I also made the text file Read-Only. Thanks again
You're welcome.
