Author Topic: filtering by VBR Bitrate  (Read 1424 times)
cynflux
Hello,
Is it possible to create a filter based on VBR bitrate?
I have noticed that some of my mp3 files have VBR listed next to bitrate number.
The filter only seems to allow numerical characters.
Thank you in advance for your replies.
cynflux
I believe I found a solution.
Using the display field called 'Encoder Quality', I was able to create a filter with a range between 0 and 10, hence a 'VBR' filter.
Be careful - I use Lame 64bit 3.100 at V0 and MusicBee somehow reports these files as V10 under properties.
cynflux
Thanks for the heads up. I am just using the filter as a quick way to distinguish VBR files from other files.
