Author Topic: More recent, custom and virtual tags not available for Theater Mode?  (Read 4705 times)
Playing around trying to create a theater mode:
Is it correct that not all tag frames can be referenced?
For instance, I tried 'Language', 'Artists: Performer', and a couple of custom and virtual tags, and I can't get any of them to work.
Am I doing something wrong?
i doubt they were added but i will do so. All the custom and virtual tags are already supported though, so you could use a virtual tag in the interim
Thnx, than it's probably me, not yet being very savvy with tm at all.
https://www.mediafire.com/file/a2io0cpe83ttz6c/mb_TheaterModePlugin.zip
i added these:
"language"
"work"
"showmovement"
"movement"
"movementno"
"originalartist"
"originaltitle", "originalalbum"
"originalyear"
"instrumentsperformers"
Ah, solved. I was using the given names for custom tags, instead of internal name (Custom1, etc.)
i added these:
That's great.
Perhaps also add 'Artists: Performer' while at it?
(I'm already content with 'instrumentsperformers', but others might prefer the former)
That's great.
Could you please also add 'Album Artist' and 'Genre Category'?
