Author Topic: now playing auto-locate in library  (Read 1037 times)
cynflux
Hello,
Is there a way to set Musicbee to auto-locate the current now playing track in the library, instead of manually pressing F1 to locate the track in the library?
Thank you in advance.
cynflux
Thanks for the response. I did verify that I have the correct settings applied. The auto-locate feature seems to stop working after I have updated the tags in a different track or the track currently playing. The only way I have found to get the auto-locate to work again is to restart MusicBee. Not sure what I am doing wrong. Thank you in advance for your response.
Do you mean with tag editor opened? Then it won't jump for an obvious reason that you're in the middle of editing tags for the file. After closing it down, it would jump again.
