Author Topic: 3.1.6512 Many Milkdrop command keys broken  (Read 1945 times)
chrisjj
On Win 7 and MB 3.1.6512 :
1) Start Milkdrop https://i.imgur.com/d79EL2Z.png
2) Press L to load preset https://i.imgur.com/kiFsk6r.png
3) Press e.g. Down Arrow to descend preset list
Expected: Highlight descends
Observed: No effect https://i.imgur.com/wZkvWk9.png
On2.5.5804.26036, this command key worked, though others that don't didn't e.g. presetn editing text input
KangNi
Hello chrisjj,
if I understood you well - you problem should be solved herewith ...
"You have to hold the [CTRL] key while navigation with the arrow keys."
https://getmusicbee.com/forum/index.php?topic=30158.msg189250#msg189250
Greetings
Hello chrisjj,
FYI... You're replying to a thread that's not quite three years old and was posted by someone who hasn't been on the forum in almost two years.
KangNi
Hello phread, Understood.
Unfortunately, I didn't bother to check OPs status.
Sorry to say this, but your answer make me feel uncomfortable. Is there anything wrong in your eyes to provide a solution to a problem that's potentially not only helpful for the OP but also anyone else who come across this thread and to make him/her happy to find a solution?
Otherwise, what's the purpose of keeping an unanswered post in here?
No offense. Have a nice Day.
Greetings.
Last Edit: April 10, 2021, 06:40:47 PM by KangNi
I don't know why my answer would make you feel uncomfortable as it certainly wasn't the intent.
I was just pointing out that not only were you replying to a very old thread,  but the OP hadn't been around for almost as long. It's like shouting into the wind.
There are many one post threads on the forum where no answer/reply has been given. And some of the threads go back even further than this one.
