Quote from: redwing on December 04, 2017, 04:24:37 AM- Disc# and Track# could be shown on the same row if the width allowsit could be expanded to other fields as well like year and original year.
If a field has mixed values when you select multiple files, vertical tag editor cannot clear the field. Tried with genre, grouping, comments tag. It clears it only when the field has the same value for all selected files.
Can you also look at disc count field?If you edit the value for this field and save, it does not save it. The value has to be highlighted before you save to make the value changed.
