Your files are not tagged properly with art, and you have the Adele picture in the folder where your music is stored, so MusicBee thinks that picture is album art for all the tracks in the folder. MusicBee automatically pulls down art for the artists in the Album Artist column, which is why those are not an issue.
The easiest way to get your music tagged properly is this:
1. Sort your music by Album Artist and then Album
2. Select all the tracks in the first album or the first single track
3. Right-Click and select "Auto Tag by Album"
4. Pick the proper album from the list. They usually will not all be correct, so make sure you get the right one with the right artist and number of tracks. They usually will not all have art, so pick one with an image.
5. Make sure "Artwork" is selected at the center left, under the art.
6. You can check / overwrite your other tags at this point and update them as needed
7. Make sure all your tracks to be updated are selected at the bottom
8. Click "Apply Tags"
Now the artwork is embedded in the file, and the Adele image will be ignored for those tracks.
9. Move on to the next album or single track
There are tools like
Album Art Downloader that will do this in a more automated way, but I've never used one and the more automated you get the more your risk things going wrong. The method above lets you check and verify things before you update them and I prefer that.
