Author Topic: scan folder for new files staying ontop 3.1.6522  (Read 1356 times)
wobbly
don't know  when this started happening ... but now if i go to
scan folder for new  files  (from file menu)   the scan folder for new  files  window stays open  until scan  is completed ..... where as previously the the scan folder for new  files  window would close once you clicked proceed
with the  the scan folder for new  files  window  staying  open it  makes music bee unusable until scan  is completed
wobbly
wobbly
As best I can tell, you posted it in Questions. I have moved it to Bug Reports.
working fine here and nothing has been changed for ages.
make sure you tick "minimise to status bar when scan starts"
wobbly
minimise to status bar when scan starts did the trick  i don't know how i missed that  .  someone must have been playing on my pc
