I tried to update the software and copy the patch files and think I was successful. I'm having a very minor issue, but it's annoying as hell because I'm using your software to update the artwork in my extensive collection. It's pretty easy, love the software overall after dealing with the likes of iTunes and various other garbage (thank you!), but this oddity has been bugging me. When I play a song back the artwork will occasionally flicker back to the old artwork I replaced. It maintains in the window above and along the bottom in miniature form, but in the big window it'll alternate every 30 seconds or so. I know you've had at least one person approach you on this in the past and you suggested a patch. I feel like I tried that and there was no change except to some of the pictures in the band folders down the left hand column. There usually, as far as I can tell, is a picture of the album at the top of the folder alphabetically. Some of them changed to photos I have never seen, but the actual artwork attached to each individual album seems to be where I want it, that is until it toggles back and forth during playback. I'm on V3.1.6512. Do I still have to patch this version to get this thing stabilized? To your knowledge, where is the old artwork still residing? I was hoping it wasn't still attached to the actual files vs retained in some sort MB software memory. Anyway, I apologize profusely if you are dealing with this same issue for the billionth time. Thanks in advance. - John
