Author Topic: Equalizer Presets  (Read 5355 times)
Logan
Using MB 3.1.6512
MB doesn't appear to be able to find any new presets that I save and place in the usual EQ path. Presets I saved quite a while ago show up just fine.
its prompting to save to the wrong directory for the standard installed musicbee.
This should fix that:
unzip and replace the existing files
you could manually copy the presets from the installed MB directory/Equaliser to
c:\users\<your id>\appData\roaming\MusicBee\Equaliser
Logan
Works a treat.
Thanks for being awesome!
