Musicbee is the best, this has been my only issue to date
I use my exported iTunes to bring into Pioneer Rekordbox, which has been working fine until recently. The main issue is that the iTunes xml created by Musicbee is missing tunes that exist in my Musicbee library and playlists. For the missing tunes, they play fine in Musicbee, look as they're supposed to and when I locate them in Windows explorer, it points to the correct file. When I manually export a playlist and bring it into Rekordbox or iTunes, the playlist is without error. But when I bring across the whole library, the playlist has the same number of tracks as the original playlist but the last (let's say) 10 tracks of the playlist are the same random song.
An example would be: Musicbee, Playlist 1, 65 tracks, last 10 tracks no issue. Rekordbox, Playlist 1, last 10 tracks are all Darude - Sandstorm.
Interestingly, when I look at the itunes xml, the first tune (key 1) of the library is ALWAYS the tune that is repeating in error (eg. Darude). Hoping this might help narrow the issue? The track that should be there, however, is not in the xml anywhere.
Thanks for your help!!!
