The inconsistencies that I reported in the first post was addressed. But there's another one. This is not between different tabs but between different selected folders in computer node on the same tab.
- Select A folder in computer node, select all tracks in the main panel.
- Select B folder in computer node, select all tracks in the main panel.
- Now select A folder again. Then the main panel shows A folder tracks selected, but tag editor and track info panel shows B folder tracks as selected tracks. At this point, if you run a command like volume analysis, it's applied to A folder tracks.
I think tag editor and track info panel should get updated into the currently selected folder.
