Hi.
Firstly, many thanks for MusicBee. Having used many players in the past, I find this is the best by far.
Would it be possible to consider adding the option on Playlists to delete a track/file once it has been played.
Currently if you play a track and then shuffle the list, that track will be repositioned and may be played again.
Many thanks for all your hard work...
