Author Topic: Display bug for the number of selected files  (Read 786 times)
If you select all files in an album in artwork view using the mouse, the status bar shows the number of selected files correctly.
But if you're using Control-A, the status bar doesn't get updated properly.
Last Edit: November 05, 2017, 10:51:39 PM by redwing
