Author Topic: Skinning Requests for 3.2  (Read 48843 times)
- Support for new (optional) player controls for bitmap skins: Play Previous/Next Album
- Image overrides for "UnknownAlbum" and "UnknownGenre"
  • MB Version: 3.6.8849 P
override for highlight border in <element id="NowPlayingPopup.Body"
(I actually think bdr attribute use to do this in 2.5)
support for extra "open Auto DJ settings" image in bitmap skins
support for highlight colouring on override "EditSave" icon
either as auto-colouring (as other icons in the header currently do) or the addition of an "EditSaveHighlight" image
Alumni
I found out that Windows color accents can be read from the following registry key, maybe MusicBee could take advantage of these values?
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Accent
Support for bg/fg for tag editor or only for vertical tag editor.
i will start looking at skinning requests in the next week or two
Alumni
I was wondering what skin elements to edit for the playlist header bar?
As for requests, it would be helpful to have an override for the status bar if player controls are docked in the top panel.
You should be able to find that with the help of: Sample Skin
I think it's using bg and fg of MusicExplorerHeader element.
@Steven;
Can you support an override for that including bg2 for the gradient? Also support bg2 for MusicExplorerHeader element too.
- Unknown album its already there as: "NoArtwork"
- I have added "UnknownGenre" for the next update. I recommend 128px for the 100%dpi image
Last Edit: March 31, 2018, 07:04:24 PM by Steven
- Image overrides for "UnknownAlbum" ...
I meant the record image that thumbnail browser shows for "All Albums" item when "Album" is selected.
Alumni
Yes this does seem to be the case, except when auto-pick panel colors is enabled then it goes by that instead.
Last Edit: April 01, 2018, 02:17:32 PM by Alumni
looking at the code, its always been hardcoded to grey. I have changed it to use the panel border colors if it is different to the background color
- for the next update, i have added "AutoDjSettingsButton". For reference, the MB one is 11x3px but it doesnt have to be the same size
- thats in the next update as "UnknownAlbumIcon"
- and in case you missed by edit: I have added "UnknownGenre" for the next update. I recommend 128px for the 100%dpi image
Last Edit: April 01, 2018, 07:02:09 PM by Steven
Alumni
Would it be possible to override the image that pops up when dragging and dropping playlist items?
Thanks!
i have changed the default save button and default colouring to be consistent with the other buttons.
In all cases the highlight background/border is the same for all the buttons, including when you have a custom "EditSave" button
