Author Topic: wasapi exclusive or event mode ,is there a way to don't mude other audio source?  (Read 2178 times)
gaiastar
Hi
i have tried in the past aimp4 and media monkey , both can play in wasapi without preclude the other application to use the audio
could be done with musicbee?
or is a limit of musicbee?
if yes ,cold i add in the whishlist?
thanks
if that is the case they are using WASAPI shared mode which as far as i am aware is no different to just using DirectSound
gaiastar
hi
but there are software like adobe audition cc or wavelab they can use wasapi or asio ,but in case of wasapi they don't preclude other application to play audio
and in this program like adobe audiotion cc there is wasapi (without any option like event or  exclusive or push)
thanks Steven
