Author Topic: Web Browser Plugin Broken  (Read 1822 times)
jaume
Hello,
It appears that the plugin has a bug whereby the top bar is broken. See screenshot:
I am using the 2.01plugin and tried to remove and add again.
Also, would is it possible to keep the web pages re-appearing at the same ratio/zoom?
Another great behaviour similar to the previously integrated browser would be that if you move to another tab and then go back to the web browser the page would not refresh unless the artist you are listening to has changed.
not sure whats going on as i have no problems with last.fm
if you send me a link to your settings file i can have a quick look
jaume
Thanks, Steven. I just sent you the file on a PM.
Note that the screen appears broken with all sites. Not just Last.fm
I just tried with your settings and all is fine for me re: the layout issue. I am afraid i dont have any ideas why it wouldnt be working for you so i will leave it unsolved
jaume
