Author Topic: help me with same albums with several different format  (Read 2442 times)
gaiastar
Hi
i have bought an album
and i have ripped in flac , after i convert on mp4 for my phone and mp3 for my car stereo
ok i have now on my computer the same album in flac/mp4 & mp3
ok i can delete the mp4 and mp3 files
but that's not the point , outside smart playlist are there some tips to help me to browse my music ->artist->album->year and extension
i use these layouts
thanks
If you right-click on the column header of the column browser (you currently have the same Artist-Album-Year for every tab) and select "Set Displayed Columns", you can adjust displayed tags and change the order. Add "Kind" tag.
Tybot
In preferences, under sorting/grouping, you can specify the criteria for how an album is defined and grouped. Adding ".Ext" to that list should solve your problem.
vincent kars
There is a better way: use MusicBee to synchronize straight to the phone or USB stick.
No need to have duplicates in different formats in your library
http://musicbee.wikia.com/wiki/Devices
gaiastar
hi
i have not kind tag
and
thanks
Yeah, you're right. Then create a virtual tag for the field (<Kind>) and add that instead.
gaiastar
hi
thanks it works!  :)  :)
gaiastar
This will make it shorter.
$Split(<Kind>," ",1)
hi
thanks ! by the way mp3 would better then MPEG
gaiastar
Yep. Here you are.
$Replace($Split(<Kind>," ",1),MPEG,MP3)
hi
wow
where do you find all these information
thank you so much
