I am using musicbee 3.1 and sometimes songs getting stuck,no matter I choose "load the file into the ram"or not it just happens.I found that when this happened the disk transfer speed will be very low(my system is in Chinese but I think that you can still read the task manager,well,I hope so)
It is strange that if I use Foobar2000(1.3.16)to play the music there will be no stutter happening and the disk status is 0%
This troubles me a lot since I love using musicbee to manage my music libaray and I do not want to change the software to playback.I must notice that this will only happens when playing high bit-rate files(pics above is got when playing 5700kbps lossless music).Hope that this problem can be solved.
