Enabling ASIO in MB settings with re-sampling off, on at 96kHz or 192kHz will result in the audio becoming corrupted. Interestingly if re-sampling is set to 48kHz (in my config) the audio works fine.
When re-sampling is off, or on (at 96 or 192), pressing next track will more often than not result in the track sounding extremely distorted and like it is played at slightly higher tempo (I assume this is a problem related to using a higher sample rate). I tested this with both Tempo control on and off.
Since I can bypass this problem by setting the re-sampling to 48kHz it is at best, a minor nuisance, but still something worth reporting.
Essence STX II from Asus, Windows 7 and MB 3.1.6505.
