Copy the files into Codec folder. Then configure it in file converter settings.
Here's how my settings look:
To change the encoder, click on ... button on the right. I don't think multiple encoders are supported for a single format.
try changing the title tag to remove the | characterif thats the reason then its a bug that i will fix
Yeah, I forgot I didn't configure for small & standard option for qaac as I don't use them (looks like they are nero settings). High, maximum & ALAC should work.
I don't understand what you mean. Post a screenshot.
