Author Topic: Visual glitch with now playing node  (Read 1672 times)
Place the main player bar at the bottom with spectrum visualizer enabled> Open now playing node> Hide player bar.
Then part of spectrum visualizer is still visible on the status bar at the bottom.
Happening with both 3.1 & 3.2.
i dont seem to be able to reproduce this. What order are the controls eg. Player; visualiser; status bar ?
I meant spectrum visualizer on the main player that is enabled by panel layout context menu.
And place player bar below status bar.
Last Edit: October 24, 2017, 06:11:48 PM by redwing
It's not fixed for both versions.
The only difference I can tell is it's no longer visible if you switch from another tab to now playing tab.
But it's still visible if you show and then hide player bar, staying in now playing tab.
The spectrum visualizer issue is fixed. I noticed this is happening to track text too only when it's scrolling (again with both 3.1 & 3.2):
This is happening with any configuration of progress bar (top, middle, bottom) and whether switching tabs or staying in the tab.
Try pause and play in now playing tab. Then it shows up again when it starts scrolling.
