- If you change the case of any word in title for first track using search and replace command, the album cover of the album disappears. Restarting fixes it. It happens only with v3.2.
I have noticed similar behavior lots of times even when using tag editor. For instance select all files in an album, edit composer (or any other fields), save, then artwork disappears from the album in Album and Tracks view. Even restart doesn't fix this (I've seen this kind of albums from time to time for weeks). You have to save the first track again without any change. The problem is it's not always reproducible to every album. This is what I have observed so far.
- You must change a tag for all tracks in an album that have multiple tracks.
- If you edit the tag to another value and save again, artwork shows up again. Once that happens, it no longer happens to that album at least for editing that tag (On second thought, probably this happens because simply first track gets saved again regardless of tags).
- This has nothing to do with its URL change or auto-organization. I've seen this from albums not within my library.
- All artwork is embedded to files.
