If I select wasapi as the output for the player, the sound I get is badly distorted, with what seems to be a mix of interference and tracks being played too fast. Adjusting the buffer size and having 'event mode' switched on or off doesn't make any difference - this issue contunes to occur.
This issue appears to relate only to how musicbee is handling wasapi. Playback using musicbee's DirectSound setting is fine, and whilst the PC is running the latest version of Windows 10 there's no noticable distortion at all when using wasapi with audio players, including Winyl, which like musicbee also uses basswasapi.dll. I'm like crazy about Musicbee
so I'm really hoping this issue can be resolved.
I'm incidentally using musicbee version 3.1.6493 and trying to get this to play, via wasapi and S/PDif, to a SMSL Q5 Pro. (This doesn't use any third party driver - Windows has instead configued it with a generic MS driver and sees it as a high audio definition device)
