It would be nice that I could press a global hotkey when Musicbee's window is not visible (background or minimized), that would popup the "Edit Tags" window So, as a standalone window popping up above my current active window and without MB window itself popping up. I'm not sure if "standalone" is the exact term, but like some other windows in MB can do, like the "Now Playing Assistant" and "..Notification". Modeless dialog?
Also, the Now Playing track should be selected for this tag edit window Otherwise you might be editing tracks you are not aware of (selected in one or the other panel you can't see at the moment)..
