Author Topic: Questions on skin elements for 3.1  (Read 6357 times)
Tommy
if your language decimal separator is "," then use ","
The language separators you are referring to in the quote above are both the same ","
Anyway, I tried values from 6.00 to 12.00 using "," and "." and tried to use no decimal separator at all but the font size won't change .......
Last Edit: October 17, 2017, 10:53:00 PM by Tommy
Tommy
Then ask Steven for help, sending him all your skin files.
Tommy
....... I think it's not that important. I just saw this new skinning feature and tried it out.
Must be something I'm doing wrong, apparently for you and others it works.
I really must say this - It's very nice of you guys trying to help people out that are not that knowledgeable - It's very much appreciated !
Thanks .......
Last Edit: November 30, 2017, 07:32:15 PM by Tommy
Tommy
