....... one more question about adding the wavebar .
Do I understand correctly that I must have 2 skin files like the skin.xml and the skin_wavebar.xml were both files are the same only that the skin_wavebar.xml must have this line of code added ?
<element id="WaveBar" parent="TrackInfoPanel">
<left relativeTo="Spectrum.Right" offset="25" />
<right relativeTo="TrackInfoPanel.Right" offset="-8" />
</element>
I tried that, but it doesn't work which means I'm doing it wrong.
It would be great to have a template or example file to work with as I cant figure it out.
Also I tried changing the font size of the Track Position Timer:
<element id="TrackPosition" parent="TrackInfoPanel" fontSize="8.00">
It makes no difference to whatever value I'm using, the font size won't change .......
