EQ isn't going to give you more power, you'd need a bigger amplifier for that. The HA-SZ1000 is actually a very low-power (16 ohm, 108 dB/mW) set of headphones; those are almost as low-power as you can get. If you would be willing to describe exactly what you're trying to accomplish, perhaps we can guide you to a simpler solution.
For example, EQ is typically used when you don't like how your headphones sound. Are you looking to change the tonal balance? In what way? How does a +/- 15dB EQ not meet your needs?
