Author Topic: Musicbee doesnt sync new files added to "music" folder  (Read 2012 times)
zac
Hi
great player!
one issue is it doesn't recognize new files and folders added to my "music" folders. I've tried the "scan folder to new files" option, but still I cant get it to work.
any ideas?
Thanks
Last Edit: October 15, 2017, 11:28:30 AM by zac
By default (I think) new files go to the inbox, not right into the library.  Are you looking there or expecting them to be in the library directly (you can do this with an option on the import screen if that's what you want)?
zac
nope.. they aren't on inbox... I just need any music file I add to my "music" folder, to appear automatically.
zac
any other idea?? I don't want to give up on musicBee, I really like it!
Have you set the folder up as a monitored folder?
