Hi. Thanks for the great player.
It's been a long story and now I'm using the latest 3.0.6335 version of Musicbee but as I wrote in subject, the option do nothing.
I tick/untick it's checkbox saving and applying settings. I tried to use different outputs - no luck What should I do to make this option working?
Windows 8.1 Pro(currently), Windows 10 Pro, Windows 7 Pro and XP of course, 32-bit
Can I use the player without this option? Sure, I can. But with it it's much much more comfortable.
