Of course. But you can't open the xmlc file with text editor, right? That's why you need to create an xml file to override the original skin. That's not creating a new skin but a way to tweak existing skins without source files.
hi
could you make just an example ?
skin stealandbee
the skin is located here musicbee\Skins\Neutral\
i want to change the yellow and main color skin
the original yellow is f8c958
and the main skin is 929292
my new color are yellow will be black 000000 and the main skin will be darker and will be 747474 (red 116 - green 116-blue116
ok i create with notpad++ a file callled SteelAndBee.xml
sould be
<root dependsOn="SteelAndBee.xmlc">
<element id="Player.Backgroundr" bg="0,0,0" fg="0,0,0" bdr="0,0,0" />
<element id="main color ?" bg="116,116,116" fg="116,116,116" bdr="116,116,116" />
</root>
can find the skin color main but is it correct?
thanks
